- Joined
- May 2, 2014
- Posts
- 225
- Reaction score
- 346
- Ram Year
- 2018
- Engine
- 5.7 Hemi
If you're waiting for FCA to do something about it, don't hold your breath.
Most of the crap you here is just that crap. The people that get on these forums to complain about the Hemi are the small few that have had some type of issue. In the real world it's not so, out of the hundreds of thousands out there only a very very very small amount of problems occurs . Just from real world experience of my own I have owned an 09,10,13,15 and now a new body style 2019 with 29k on it so far. The four other trucks I mentioned were driven to over 130,000 each with absolutely zero issues and went to the dealership for oil changes and tires only. The oil changes were done at the end of each month due to the mileage I put on the trucks so oil was changed twelve times per year. I had to buy two sets of tires for each truck because including the original tires that came on the trucks I needed three sets to make the miles I put on them before tradeing for a new one. I have never ever had an issue with the Hemi or the Ram truck in general and most everyone I know can say the same. Don't worry about your truck, just keep the oil and filter changed regularly and do the required service when called for. You will get many miles from your Ram!
I'm sure this topic has been addressed, but I just became aware of this Hemi disaster. I have a 2016 Ram 1500 with 16k miles...I only use it for recreational purposes & use my 2000 5.2 Ram for a daily driver...If the 16 Ram sits for a period of about 2-3 weeks I get a bad lifter noise at start for about 3-5 minutes at idle, then it goes away...Using the truck daily is fine no noise.... Now I find out that the design of the engine is the cause starving the cam & lifters of oil. Something about a cast baffle part of the block preventing the splash of oil to the cam....I also heard the dealers are plagued with failing Hemi's with both cars & trucks. Disappointment is an understatement...My question....What are other members experiencing? Is Chrysler doing anythng about it?...Would greatly appreciate any input....Thanks.....
