Yummins24
- May 13, 2012
- 23
- 0
- Location
- Maryland
- 1998
- Magnum 5.9L 360
So yesterday me and my dad replaced the MAP sensor, the TPS, and the IAC in hopes that it would solve our problem with my truck starting to stall when at idle... it solved that problem but a new problem arose and that is that when we took the truck out for a test run we noticed that the truck was hesitating to shift and almost dying when I wasn't on the gas... when it did finally shift after stepping the peddle to the ground it was almost a real rough shift and kicked into the next gear. After driving for about 15 minutes the problem goes away and the truck rides perfect. It is an automatic transmission. I would really appreciate your guys thoughts and ideas of what might be wrong. Thanks
