Sterling
- Dec 20, 2016
- 24
- 0
- 2001 offroad
- Magnum 5.9
Thanks for all the info. I have a few questions because I'm not sure what I'm doing.
If you remember my ac compressor is not coming on.
I jumped the compressor to the battery wand the clutch didn't engage so the clutch is shot.
My question is if remove the ac relay I have 13 v at the relay but if plug the relay in the voltage drops out. I measured this with fine wire on the relay prongs. I know you said the computer controlled this. Is the computer looking for an amperage draw somewhere or looking to see a pressure switch open/close.
If I stick a paper clip in 30&87 I have voltage at the plug but not with the relay
Thx
Thx
). Pin 86 should always battery power, it should never switch on or off. Pin 85 is connected to the PCM and should have and lose grounding as the compressor clutch is cycled on and off.
