RAMnCali
My new HID fogs stopped working shortly after install so I'm looking for suggestions. Here's the basic rundown:
- 2007 QC with factory fogs- swapped in 35w fogs
- During install/testing both sides were functioning.
- After final install, checked again and driver's side wasn't working
- Double checked connections, polarity, etc and no loose connections, no grounds used with plug n plug setup
- Switched bulbs to check for bulb/ballast issue; on start up after switching I noticed a horrible burning smell and neither light was working
- Closer inspection shows that the bulb originally on the driver's side smelled burnt and had discolored gas inside the bulb
-Now neither ballast will function correctly even when connected directly to the battery terminals
After contacting the company where I ordered it, they offered to charge me shipping and full price to send a replacement and refund me for the 1st kit if it is determined to be faulty, after I also pay return shipping for the 1st one to be tested. Any ideas how I can get this fixed?
