Kelly
- Joined
- Feb 21, 2018
- Posts
- 20
- Reaction score
- 14
- Location
- Vancouver, BC
- Ram Year
- 2016
- Engine
- Eco Diesel
Try clocking the bulb where the wire is at 6:00. You will probably have to take off the plastic retainer (3 little screws), clock the bulb, then install the retainer with the bulb in place (as opposed to just inserting and screwing in the bulb". The retainer will only go on in one position. That took care of the shadow issue I had for the most part. There is still a very slight shadow, but nothing like before (my before looked exactly like yours).
Thanks!Try clocking the bulb where the wire is at 6:00. You will probably have to take off the plastic retainer (3 little screws), clock the bulb, then install the retainer with the bulb in place (as opposed to just inserting and screwing in the bulb". The retainer will only go on in one position. That took care of the shadow issue I had for the most part. There is still a very slight shadow, but nothing like before (my before looked exactly like yours).
Pretty cheap from Amazon, the slim ballast fit in the housing so no drilling out the cover...Looks like a nice crisp cutoff. What hid kit did you put in?
