HID projector stuck open...
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Has anyone else had this problem? I'm blinding people with my left head light.
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
I'm thinking it must be stuck because the high beams are working fine(Quads). Anyone know of an easy fix?
Alex
Weyburn, SK, Canada
2015 Mustang GT
Occasionally my left projector will stick in high mode as well, it will return to normal if I flip the highs again. I kind of look like a tool at night dimming then flashing, but better than leaving that one in high mode
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Thanks man, I tried that... Maybe I'll just unhook the power and see if I can get it to come down and then just leave it closed.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
If it doesn't release, sometimes a quick tap on the headlight lens will pop it back up.
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Thanks for the info guys! gonna screw around with it today
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Well… they were working okay Briefly. Now its back to high beam mode all of the time. I wanted to take these apart and paint them over the weekend but it was just too cold. In the meantime, can I just unplug the projector? Or will that mess up the whole low beam? Again I didn't retro these, so I'm not entirely sure how they are wired. Thanks in advance!
Alex
Weyburn, SK, Canada
2015 Mustang GT
If you open the dust cover behind the high beam bulb, there should be a set of wires coming from the bulb heading into the headlight, this is the trigger going to the projector. Unhook that and the projector will not get the signal to open up, so that projector will stay in low beam mode
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
Thanks Alex, That what I thought… Just didn't want any surprises
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
bingo.
If its still stuck............grab a paper clip, stick it in there and pull that butthead back! (gently.........)
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
I think I hate these projectors… I unplugged the left one, and now the right one is acting up. Oh, well. I think these are the H1's. Does anyone know of a more reliable projector that will fit into the quads? Or is it possible to put a heavier spring in them to force them into low?
LB3711
Trumbull, CT
3.6L V6
to me sounds like theres a bad solenoid inside. I'd take it apart and fix it. Might be binding or something loose or broken in there.
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
I'm gonna unplug the other one and wait it out til spring. I'll take them apart and do it right when the weather is descent… Thanks for the input
sausec17
Banned
ATLANTA
honestly, I never hooked up my high beams specifically for this reason. it sucks to not have high beams bc of something so small and stupid like that, but its whatever.
strap an led light bar on there instead :)
Westwind1124a
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
That would work too! Actually, I'm running hids in the highs also so its not too bad. I just liked the light output from all 4 hids in high mode. they're badass!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what version of the MH1 do you have?
DJack
