HID wiring Harness question
toppyw
I have a complete set off of a 2009 RAM and now am wanting to know if the wiring harness from the 2009 will work for the 2014. Both have the quad headlights.
Thanks
txtrucker75
you could look up the wiring specs for both trucks and it will tell you for sure if it will work or not
bobosky520
HEMI 5.7
I bought a set canbus HID, plug and play without any harness
Valth
Odessa, TX
how does that work? link to info?
I just got a set of 3five with can bus adapter from retro shop. You plug your light in then the blades connect to old plug fir the light then that plugs to the ballast and the adapter goes to the ballast to and the other two wires on the light go into the adapter, it's practically dummy proof and simple, I've done it both ways and this is by far the fastest way to do hids, and they look amazing
iam_canadian22
northern ontario
Thanks
If both lights are quads your all good
