High and lows
PRae23
I had my headlamps changed out. Simple enough. But now my right headlights don't work at all. High or low. Fuses are good. Relay clicks. Bulbs are new and good. What else could be the problem
Did you just change the bulbs with halogens? or "upgrade" to LEDs?
If halogen replacements, check all the wiring connections as the pins inside the connectors may not be fully seated.
If LEDs try the headlights with the ignition on but the engine not running. If they still don't work the try putting the halogens back in and troubleshooting the connections and pins.
P
PRae23
I used the exact same bulbs. They are halogen. I just switched the assemblies. Even more reason there shouldn't be a problem. i will check the pins tho kusy to make sure
joshhhh
