High beams not working?
EWC88
Southern NJ
So till weather gets better to put my HIDs in I put in normal bulbs. I've had them in for a month or two and noticed a issue recently with my high beams. I don't use them often because they suck, use to the brightness from HIDs. Well I went to turn my high beams on last night and realized when I lock it in to keep the high beams on it shines the normal output, if I just hold back the lever (whatever you call it) it'll show the high beam brightness. What can be the issue?
