pwaite92
Got a whistling noise that sounds like its coming right up through the throttle body. highest pitch at idle and gets lower until about 40% throttle or so then goes away. Pretty confident that points to vacuum.
Co worker looked down throttle body and said he saw oil pooling in the bottom of the intake.
When the shop was replacing my cracked head awhile back I brought them a hughes plenum plate to put on. Magnet is not sticking to it so it looks like they at least put it on.
Do you guys think it's most likely the plate leaking?
Engine is running fine so far.
