High pitched ringing sound
JS1500
AR
About a week ago I noticed an occasional faint but high pitched ringing sound when I was driving my truck. When I've tried replicating it I've found that it can only be heard between 1,500 - 2,000 RPM and 2,500 - 3,000 RPM, and in several different gears. There is no sound when idling, only when driving. I've also noticed it when coasting downhill with no throttle input. It's hard to pinpoint exactly where it's coming from, but I don't think it's coming from the engine/under the hood (but the sound is so high pitched that it's really hard to tell). Based on my research I have come up with these possible culprits, though I have been unable to find any forums where someone has described my exact issue:
- rear end
- oil pump
- power steering pump
- pulley's/belts (but if this was the case it seems like the noise would be constant and would still be heard when idling)
- transmission
I dropped it off at the dealer today for this and some other issues, but I just wanted to see if anyone has had the same problem and found a solution.
huntergreen
Marine Corps Navy Badge
Had something similar. Only happened on hwy when the wind was blowing. Dealer replaced passenger side doorcseal and all was well.
Bighorn 866
6 cyl
I have a similar sound at 11000 rpm. Cannot pin point it. I was also looking for help here with out smart answers.
Elio
Florida - FLX Central NY
Hemi 5.7L e-Torque
I have been searching this forum for this kind of (high pitch) Ringing sound which I just noticed while driving 25-30 MPH with my windows open. It's only sound when driving.. Unfortunately, I did not find any answers to this problem (that was first reported 8 years ago!). Does anybody has any idea where this ringing sound is coming from? thank you very much.
Elio
Hemi 5.7L e-Torque
Can you please tell me what was wrong with the drive shaft? was it loose or anything else? thanks.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Wasn't loose. They are/were designed with stuff inside (they used to use cardboard, sand or springs) to eliminate any harmonics / slight vibrations in the shaft.
The F150 I had didn't have anything and it did indeed set up a harmonic in the rotation and "sang". New driveshaft and no more problems.
Daw14
South Florida
Try wrapping one layer of duct tape on the shaft , it may need it in a few spots .
But is easy to try , and reverse the process if no difference is found.
Elio
Hemi 5.7L e-Torque
Last I looked under I've noticed quite a rust build up around the drive shaft and joints from driving up north country. I'd need to have them checked and definitely lube all joints. I hope i dont have to replace it. thanks.
Elio
Hemi 5.7L e-Torque
the chirping sound just Disappeared all the sudden. On my next service coming up soon I'll have them check and definitely lube the area in question. once I back home (north) I'll have to scrap all the rust and treat the under carriage properly. thanks for all the respondents.
Bettula
