Hikari led bulbs
kooler1
Anyone tried these as headlight replacements? If so how did they perform as far as not flickering or durability? I've seen several people running them as fog lights but not sure how they'd work for headlights. Price seems pretty good https://www.amazon.com/HIKARI-Headlight-Conversion-Lumileds-Warranty/dp/B077BT6M6Z
I have them in my high beams. One flickers. They are bright but my low beams are just as bright as my highs. Not sure if the Flickr is a fluke or not. Only passenger side does it. And only when the truck is running. I do have a complete spare set. Just haven’t had time to replace the one to see if it goes away. For the price, they are decent.
N
Noeyes
Kentucky
What are you running in your lows? I've got the reflector headlights.
N
Noeyes
Kentucky
Do you like them? I mean compared to the factory bulbs were they worth it and did you use an anti flicker kit with them? I appreciate the help buddy.
N
Noeyes
Kentucky
Get led cancellers to fix the flickering but I suggest led headlights with external drivers not the all in one design as those. Good luck!
Have any suggestions on which kind? When it comes to led bulbs I'm kinda lost. I'm used to replacing regular bulbs with brighter ones. I just want something a lot brighter than what I have hopefully without having to spend 180$ a pair like the gtr bulbs I saw on YouTube.
N
Noeyes
Kentucky
2018 express with the reflector style headlights. I'm sure projector would probably work better but I'd like to just swap bulbs for brighter ones than what I have and keep the housings that I've got.
firemedic10584
Central Fl
Anytime you buy a replacement LED bulb for your truck, make sure to type "canbus" in the title as well. You'll find what you're looking for and what will work for your truck that way..
Reticle918
