Dantra
- Aug 13, 2019
- 97
- 150
- Location
- Martinsville Indiana
- 2020
- 5.7
Save some reading.. Hikari Lows and Fogs pictured on page 4
Figured I'd give some LEDs a shot in my projectors and ended up deciding on Hikari Ultra LEDs after reading an impressive review on bulbfacts.com. I also wanted to support a local shop and try their Firewire LEDs. When comparing the 2 mfrs side by side there's no comparison..
Hikari Is impressive. Better fan and cooling design, lower profile and came with drivers. They seated nicely into the housing and are completely clockable.. The base ring can be turned and and if it won't turn enough just twist off and put back on in a new position I clocked one side at 9/3 and the other at 3/9 . Power cord is 6 o'clock. Seemed to make no difference.
The Firewire LEDs came off as flimsy, poor cooling design, crazy size and did not seat well into the housing.. Felt loose. The fire wires were so big that I couldn't even get them into the high beam socket. Tried them. In the low and they wouldn't even power on. Wouldn't power on in the fogs either. On top of that.. They cost more! I really wanted to support locally but considering these factors, they'll be going back and I'll order a set set of of another brand off Amazon. Gotta read up first on reflector style reviews.
Below are some pics.. You'll figure them out. A before shot, Some are comparison shots, one of side by side of halogen VS led and then some road shots. A few with or without halogen fogs on.. You'll be able to tell. You'll notice that when the led lights are shined onto drywall that there is a dark void on the bottom side but the upper cut off is crisp. The void isn't super noticeable on the road and it I'll improve with proper fogs I didn't have to adjust anything. The best test will be driving to work in the morning.. Dark highway cruise. I'll be back with some shots tomorrow and in another few days with additional led highs and fogs.
