Hood flush with fender?
REQN
Corpus Christi/San Diego
2011 Laramie 4x4
My hood doesn't sit flush with the fender, and since I recently moved to South Texas (I don't remember what life is like without wind haha) I see it fluttering A LOT. Is there a way I can tighten it or do something to make it more stable, without going to a body shop? I mentioned earlier that my remote start stopped working (reason: hood ajar warning). Any help appreciated!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Check the points near the cab of the truck, where the hood connects to the hinges, see if they're loose.
REQN
REQN
2011 Laramie 4x4
Honestly, I reached up in there just now and can't get a good feel on if it is tight or not. Cant even judge the size of the bolt it's tucked away pretty good
BlackedOutHemi
DFW, Texas
2012 & 2012
Is it tucked up tight? If you open the hood it should be pretty visible on the left and right sides. I can't imagine it being hidden because you need to be able to get the hood off.
REQN
REQN
2011 Laramie 4x4
It's not completely hidden but I can't get enough on it to see if theres more tightening that can be done
REQN
REQN
2011 Laramie 4x4
Sure is. Just trying to avoid taking it there (since I have no idea how good these guys are).
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what about the bumpers? there are little bumpers under the hood that you can raise to help that.
REQN
REQN
2011 Laramie 4x4
I raised those some but it didn't do anything to help the wind shear and hood movement
quietpeen
2021 TRX
Hellcat
raise them a little more? my hood had a little wobble on the highway on the drivers side....i raise the bumpers not much at all and the wobble is gone
REQN
REQN
2011 Laramie 4x4
JJ wins for stopping the shimmy! But I still can't get remote start to work. Any more ideas?
BlackedOutHemi
DFW, Texas
2012 & 2012
Is it because it thinks the hood is open, or another reason?
REQN
REQN
2011 Laramie 4x4
Message on dash says "Remote start aborted- hood ajar." But it is definitely closed.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
i bet the pin is sticking?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
tape the hood pin down. :D
LB3711
Trumbull, CT
3.6L V6
check to see if its plugged in. its right on the latch. easy to check. Jump the 2 wires on the plug and that will test the circuit that it works
09SMOKINHEMI
TEXAS
I'll have to try that. I noticed that when I went on my road trip last week. I was afraid my hood would fly up on the highway
