It is trq management, as well as not being able to COMPLETELY dissable traction control, I mean the 33 inch tires don't help by any means, but it isn't a huge factor. Wheel weight is thought to make a huge difference but even then the biggest factor is Diameter. Getting shorter tires will help, say 31s or something like that, but the biggest problem is not having a tuner to turn trq management off as well as traction control. Also the 390hp is to the crank, not to the wheels. With drive train loss we are looking around 310 to the wheels on a good day in a stock truck. Which even then should break the tires loose. That would be if there were no restrictions. I mean think about how little HP muscle cars of the 60s-70s had compared to todays standards and how easy it was to lay some rubber down. Those were the good days of not having a compootinator drive for you.
