How do you remove the panel under the hood
hdvespa
Southwestern PA
Went to use the windshield washer today and noticed they were not working but fluid coming out if the corner of the hood. I assume the line has a break. So how do I remove the liner without damaging it. How do you remove the clips holding it in place to gain access to the lines to the washer fluid nozzles
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Have you looked under the hood yet? The break is usually right at the hinge. The plastic lines are junk. I've had good luck using vacuum hose to jump across the break.
Sent from my SM-T500 using Tapatalk
H
hdvespa
Southwestern PA
Barney556180
Don't need no stinkin' mask...
Northern Michigan
Barney556180
Northern Michigan
H
hdvespa
Southwestern PA
Well one of the ports broke at the nozzle and while messing with the hose I broke the other nozzle. Now I need to replace both nozzles. Any recommendations on which ones to buy and from where
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I believe Dorman has a pair and they usually make a good product and your local auto parts store may have them in stock
Socalramfan
Huntington Beach
2011 Big Horn
Easy to do, but do them both. Heat causes the plastic to dry and become brittle over time. You'll likely need to adjust the spray afterwards to direct it where you want it to hit on the windshield as well. Just use a safety pin or the like :waytogo:
Elvira
Somewhere
I had to use a tool that is used for an entirely different job. But it did work perfectly, you could use side cutters if you are gentle not to cut the plastic peg. The picture will give you an idea of the tool needed.
cdub5
