how involved is swapping the dash
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
Is swapping the dash for a higher level leather stitched unit a royal PITA? Didn't see a write up by I may be using the wrong term. The part above the glove box/radio/around the spedo up to the wind shield that would get covered with a dash mat.
2010 Infantry Vet
Butler pennsylvania
Yes!!! I had to take mine out to run a speaker wire to my center dazh speaker hole, but never was able to get the dash complely out. You have to remove about 60 bolts and screws and i am not exaggerating. Not to mention disconnect battery and remove the passenger airbag.
kkreit01
Olathe, KS
..and although the leather dashes look great, I believe the are troublesome. (peeling, etc.)
