How Many Miles on you 6.4 Hemi??????
MSgtZ
Lakehills Texas
95000+ on my 2014. Brought 9 months ago with 77,000 on it. Tows my 14' box trailer at 7,000lbs loaded and my daughters 29' TT at 7,000lbs with no issues. Other than a heater core replacement no major mechanical problems (a rear axle hub seal) at all and runs wonderfully.
Halligan
Massachusetts
61,000 miles on my 6.4 using PUP 0w40 and so far so good. Going to be changing diff oil, transfer case oil, air filter, cabin filter, and power steering fluid this week.
BLUKTY2
Don't forget the brake fluid. Very easy to do and cheap. In my opinion, brakes are THE most important system on any vehicle. I change mine every three years, Chrysler recommends every two years iirc.
Halligan
Massachusetts
I agree 100%. I'm going to doing some brake work in the near future and that will get done also.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Yeah I am changing out the front calipers on mine due to one sticking a little. Only 68k on it & the brake fluid looks pretty nasty. When I pull my trailer I am sure they get really hot.
Coltws
Grangeville Idaho
6.4 hemi
I was waiting for the magic half a mil!
Sent from my SM-G950W using Tapatalk
What fuel did you run in your 6.4 hemi. I am trying to decide if it's worth running none ethenall or run the recommended 87 or 89 octane. And while I'm asking questions did you find any brands of gas that seamed better to run than others. Thanks
Jughed
Eastern Shore
2018 Crew Long Bed
56K on the 6.4. 1/3+ of that towing 10k+/-.
Vibration/shudder issues for the past 6 months - bad vibrations turned out to be tires, slight shudder still present. Dealer changed the driveshaft but it didn't help.
All fluids will be changed in the next few months, starting with the trans. See if that clears up the issue.
smurfs_of_war
Swift Current, Saskatchewan
87 in mine all the time. I get my fuel in bulk at the farm, so it's always coop or petrocan. Can't say I see much of a difference.
Sent from my VOG-L04 using Tapatalk
Pktatum95
Ohio
6.4 hemi
Like SMI, imma hotshot guy. 209k on the clock. Still runnin everyday.
-2017 3500 6.4 hemi reg cab 4x4 DRW
-66rfe tranny (still original-**** ton of tow miles obviously. Strictly work/hotshot truck, 95% of its life has been under a load)
-4.10 rear end (still original)
-no issues with 4x4 or front drive shaft
-lifter failure at 93k (new long block courtesy of FCA)
-like SMI, I’ve ran Mobil 1 0-40 for all miles up to 200k. Recently switched to redline 5-30. Mobil 1 m1-113a filters.
-it’s a actual 3500, not a cab and chassis. Although now I’ve pulled the bed off and runnin it cab and chassis.
-only other issue was radiator was clogged and not cooling. New radiator and hoses at 127k. And a new starter around 180k? Maybe. No other issues.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
Just bought my 2018 3500 6.4 hemi this past spring with 42K on it. I'm hoping this will be my last truck purchase....
Pktatum95
Ohio
6.4 hemi
13 Months Old Still going strong at 183,000 miles
Yes, really 183,000 miles and adding about 13,500 monthly.
No other problems except the ones listed above. Even still have factory brakes.
You have me beat on the load weight. My heaviest load was a custom Ram 2500 and a 4Runner. Scaled at 26300 lbs. Transported from Michigan to Texas.
I know you have many man
Just a quick update:
My truck turned over 400,000 miles today. Now that the engine is broken in, we can see what it can really do!
Happy Truckin To Everyone
are you on original tranny with the 66rfe? And If so, what is your service schedule like?
I have 215k on mine and I also hotshot. Adding 8k miles +\- monthly.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
'21 with just over 9 thousand kilometers and 1 oilchange.so far so good!.my old 2500 5.7 had over 200,000 k with just a plug change and the manifold bolts replaced.besides brakes.that was it for the entire truck.that truck was a tank.
jambbii
Mesa, Az
26k on my 18 powerwagon. I tow 11k from 1k above seal level to 7k above in less than 2 hours (camping). Runs perfect even when it is 115 degrees in Az. Trans let go without warning at 18k.
Goodie1990
