How Many Miles on you 6.4 Hemi??????
Obxram
Google
That’s 447 miles a day for 17 months and you say you park it some times. Your rear must hate you.
busterbrown
Detroit, MI
2017 Ram 2500 Megacab Laramie
All on my 2017. 17 months old today. Parked at least 1 day a week. Sometime more.
So, I just read the previous posts in this thread. I saw your first post on Nov 22, 2017, a mere 4 months ago. You had 183,000 miles on your truck at that time. You racked up 45,400 miles!! I hope that truck is making you some serious dough. Glad to hear you've had little if any problems.:waytogo: Can't wait to see your mileage update in 1 year!
McBroom
Denison Tx
Hemi 6.4L
I was told by my dealership that the 6.4 will last 650K before first rebuild. I guess I’ll have to wait n see. I have 2600on mine so far and love itbcf48c9bd36c39ec88dac442fd5be49f.jpg
I Love My 2018 RAM 2500HD 4x4
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
If any of you are wondering how long your brakes will last, I just changed mine at 228,400 miles. They were at their limit just a few thousand miles left.
So relax, most of you will never need to change your brakes.
Remember, I tow 2 cars behind my truck.
That is just crazy!!! Even to see those numbers on a pavement princess would be impressive but with you always pulling trailer that is just major impressive! If RAM could pull this off for all of their trucks it would "RAM" the others out of the market. LOL
Haven't had to replace a battery? Been hearing that people are lucky to get 2-3 years out of them now days.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
That would be awesome but I feel that is a little far fetched. That would be even pushing it for the Cummins Diesel.
SMI
Mancelona, MI
2016 2500 SLT
Update on my truck, currently 240,000 miles.
Since my last post there have been several issues all have been resolved.
It took 2 dealers to resolve the miss-fire issue below. The truck was out of service for 6 weeks. Nearly all due to the miss-fire issue.
The first information is what I gave the dealer when I took the truck in.
Ken Adams – 2016 Ram 2500
History or other issues. Please correct what you can.
First Issue:
Starting around 80,000 miles a P0704 error was given and the torque converter quit locking up. However, if I stopped and turned off the key and restarted the engine, all was fine until it happened again. This might work for an hour or two or all day.
At around 95,000 miles I brought the truck in and mentioned the above, but more importantly, the 4th gear only problem. The
transmission solenoid pack was replaced. I was told to see if that fixed the P0704 problem. It didn’t.
Later a recall on the transmission solenoid pack was issued and I had it replaced again. Once again was asked to see if that fixed the P0704 problem. It may have helped a little but still could happen 2 to 3 times a day.
This problem has been with me now for over 150,000 miles, so if there is anything you can do to fix it would be great.
Second Issue:
Misfire On Cylinder 2 and 8 and random Misfires. I replaced the plugs about 70,000 miles ago. A few times when the engine starts it Misfires. It has, a couple of times, started roughly and then stalled. When re-starting, it would crank for about 3 to 5 sec. before staring. Runs fine driving down the road.
Third, and the one I am most concerned about:
About 3 weeks ago I got an engine over heated error pop up.
The temperature gauge was all the way on Hot. I immediately pulled to the shoulder and turned the engine off. Checked under the hood, all looked OK, and the engine didn’t seem to be hot. Went back in the truck to check the temperature and all was normal. I started the truck and continued without any issues.
This Wednesday (4-3-18), over a 2 hour period, this happened 5 times.
I would pull over, turn off the ignition and restart the engine and all would go back to normal. Just false information, the engine was never hot.
As I am writing this, I just arrived from Arkansas, and all error lights are currently off and all is fine. This, however; could change when I drive it to you in a few minutes.
Thanks for all of your help. Let me know what you find as soon as you can so I can plan next week for the truck.
If you have any questions, please call me.
The first dealer fixed the transmission issue by pulling the transmission and replacing a pump.
They also replaced a sensor that corrected the overheating error.
They had the truck for 3 weeks without finding the miss-fire problem.
I picked up the truck and went to another dealer where I already had a earlier appointment for a wheel bearing and ball joints. I asked them if they wanted to check out the miss-fire issue and they said they would.
Results and another 3 weeks.
They replaced the right head after doing a leak down test.
After they removed the head, they found additional problems.
The cam shaft was in very bad shape. It looked like it had been running without oil. All of the lobes were pitted and scared. the cam bearing surfaces were fine.
They replaced the right head, cam shaft, lifters and push rods. In addition, the radiator had a crack on the top, so it was replaced also. This all was done around 235,000 miles.
The good news, all of the above cost Just $100.00.
The first dealer didn't charge me the deductible.
The truck runs and drives like new 5,000 mile after the repairs.
Sorry for the long post.
busterbrown
Detroit, MI
First Issue:
Second Issue:
Thanks for the update.
ColeRay92
Really sounding like the MOPAR Lifetime Warranty will be worth the money if I keep it on the road long enough to see those miles.
But a good dealership will make that better. Your dealership doesn’t seem to be very capable of finding/fixing issues.
McBroom
Denison Tx
Hemi 6.4L
Just a pinch over 6K miles.
I Love My 2018 RAM 2500HD 4x4 Off Road. 6.4L. USMC (ret)
Firebird
2019 Ram 2500
I met a guy recently who was in a 2500 Hemi, so I went over to ask him how he liked it. All my 2500's have been Diesel's.
He was real nice, truck was 18 months old and he had 138,000 miles already. Turns out he has 5 of them, and they do all of the Chick Fil A renovations around the nation. He said he buys the Hemi because of it's durability. He runs them up to 450,000 miles each and then trades out. Has never replaced an engine yet.
He tried GM trucks and they couldn't hold up at all. I'm glad I met him, as he is one reason I was willing to try the 6.4 myself. Bought mine yesterday, and hoping that it is my final truck.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
That is awesome! I love it! Thanks.
Bock
Lawrenceeville GA
This was very good info, and your dealers sound great they are not giving you the run around and the second on found and fix your problems. The life time warranty in your case is priceless and if your dealer don't stick it to you, you are golden. Have they ask to see any proof of service maintenance, like oil and fluid changes? Or any problems with the fact you add airbags? I am guessing you work on your truck your self.
Thanks
SouthTexan
408 CTD
Ditto, and glad you called that out. Same goes for those who think that every 6.7L Cummins, no matter how it is used, will go up to a million miles before an overhaul in the Cummins forums just because a few rare cases have done it. Some people would rather believe a lie than the truth when it comes to things they favor.
River19
"Live" VT, Work in MA/RI
Hemi 6.4L
They lost me at "I was told by a dealership......."
SMI
Mancelona, MI
2016 2500 SLT
Thanks
As a note: I currently have trucks that I have purchased from both dealers.
The first dealer tried hard to find the problem. They replaced the ECM, Coil Packs and Had 2 Mechanics check it out and both pulled the intake manifold to check the Cam. Guess they couldn't see much as the Cam was severally pitted. Because they had the truck so long, they didn't charge me or Chrysler anything. One issue however, they wanted me to approve pulling the head to see if there was a problem, but, If they didn't find anything, I would have to pay for the labor. I declined. Being that the truck was running fine, they suggested I drive it til it gets worse.
Second dealer:
I had an appoint for a wheel bearing and ball joints so I told them about the miss-fire issue and what the first dealer said. They said they would find and fix the problem. The only issue was they had to get and approval from Chrysler as the repair cost was over $3,000.
This added a few more days.
They did not ask for any service records.
Cougs57
Wisconsin
Bought in December and have roughly 3,000 miles on it. Bought the 6.4 because I couldn't justify the Cummins at this time as I do not haul that much. Need it for plowing and seating a family of 6. So far I love it (besides the 2 recalls I have on it). :)
smurfs_of_war
Swift Current, Saskatchewan
Well I just passed 67,000kms (41,000 miles) today on my 2015. I have put 30,000+ kms on in the last 18 months. Still chugging along filling up with 87 octane from a crappy old gravity fed farm tank!
Sent from my SM-G950W using Tapatalk
McBroom
Denison Tx
Hemi 6.4L
12,400 as of today
I have loved every single mile too
Blue Streak Pearl off-road
AFMoulton
Nuevo Mexico
7100! LoL
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper Stt MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
ROYSZZ4
