- Apr 6, 2013
- 115
- 34
- Location
- Utah
- 2013 Laramie , 2023 Laramie
- Hemi 5.7 8spd, 6.7 CTD
If you haven't leveled your truck you probably have 2-3" of rake "ass higher than the front " without the weight distribution sway bar attachment and 500lb hitch weight I'd say you'd be about level maybe a tick low in the rear but you'll be fine .
Once you get the weight distribution kit and air bags you will be fine even with the camper loaded for use .
The 3.92s will help , if you have the 8 speed you probably will loose 8th and maybe 7th gear with pulling 5k .
Please post here your outcome , I'd be interested in how it turns out .
How long is this pull gonna be ?
I have a 14 with the 6 speed & 3.55s , I hauled a camper 7500 lbs dry weight for a buddy and my truck did " ok " , I wouldn't want to haul anymore than that though !
Good luck !
I pull an enclosed 20' and loaded it is upwards of 9000 lbs I do have 3.92's and I have the Air Lift 88365 LoadLifter 5000 ULTIMATE Air Spring Kit. It maybe a little overkill but it is one of the best things I have done to the truck anyway 900 lbs tongue weight or so this bag kit no equalizer 10 psi and it sits level. Let the 8 spd do the thinking it is more than capable and ready for the challenge.
