How to Add Overhead Console
Express Man
No you can't buy separately. I had to buy a second console in order to get a blank.
Sent from my SM-G900R6 using Tapatalk
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I now have 2 rear window switches!
Express Man
Lol think everyone is in same situation unless you have a blank slate already lol I had four different consoles total to get the pieces I wanted lol. If your vehicle didn't come with overhead console it probably didn't come with the stuff that switches are for.
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
Yep. I've got a console with the switch port, but no switch. Hahaha. Just waiting for a local junkyard to get one for me to swap.
Express Man
Or you get that
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
Anyone have any leftover pins from they're installs? Looking for the "FMALE 150 SERIES TIN CBL RANG 2.40-1.70MM" everyplace I've checked is on back order.
coolemoff1
well heck i guess next question is has anyone thought about wiring something in to the rear window switch as in a light bar for backing the boat etc
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I have, and if I do, I will gladly offer up my blank. It's just gotta look good before I do it...
GYSOT
2014 Ram 1500
If you need the switch I have an extra one. I have to find it but I have it some where if you need it.
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
No, actually need the blank. And some pins. Thanks though.
GYSOT
2014 Ram 1500
Sorry I know what the plate is but what pins are you referring to?
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
The pins for the Cupholder LED connector. I got the overhead with no harnesses or wires, so I'm having to make them. I've got the pins and connector for the Compass Module, the kit for the Map Lights, and the Connector for the Cupholder LED. I just need the pins to populate that connecter.
That and if TASCA ever sends my bracket.
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
When populating the green connector behind the Headlight switch, is it just push the new pin in or do you have to release the terminal lock first? If so, how do you remove/release it?
Edit: Sorry, what I meant was the plastic white retainer.
Edit: Figured it out
R.L.K.
Bristol , Tn.
I'll be adding the compass module soon , pleas Sir if it's not too much trouble post up some pics of the connector and details on the pin install into the connector .
Thanks R.L.K.
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
Thanks R.L.K.
No problem at all. I'll be sure to take lots of pictures of the entire process once I get my bracket in from TASCA (been three weeks waiting).
I actually have an extra connector for the Compass Module as well as the LED Cup Holder. I don't have the pins for the LED Cupholder connector however, they're on several weeks back order from every Vendor I could find with them. But if you want, I can send them to you. PM me.
R.L.K.
Bristol , Tn.
Thanks for the offer , I have my harness already , I got it special order from the harness connection.
I'm just interested in your pinout and such to compare it to mine .
Thanks again for the offer Sir !
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I noticed that getupkid is back on the "z" forum and has 2 complete OEM headliner harnesses for sale if anyone is interested...
Padre675
San Antonio, TX
2013 Tradesman Crew
4.7L V8 FFV
Ok, my pinout is:
[Bottom/Male Connector]
1 RD 20 FUSED B(+)
2 OR/VT 22 LIN BUS CBC 2
8 BK 20 GROUND
10 YL/LB 18 READING LAMPS DRIVER
11 YL/VT 20 COURTESY LAMPS DRIVER
12
13
14
15
16 BK 18 GROUND
[Top/Female Connector]
11 M11 YL/VT 20 COURTESY LAMPS DRIVER
12
13
14
15
16 Z910 BK 18 GROUND
Verified on the connectors and on Techauthority. I'm on Techauthority now, if you want to PM me your VIN I will let you know what you've got/should have.
jhicks1983
