How to make the truck ride more smooth after lift?
CoreyLRam96
I've recently lifted a 1996 Ram 1500 (2WD) and it does ride a little rough over bumps and I've definitely noticed I feel every bump in the road or imperfection of the pavement. Anything I can buy to get the trucks smooth ride back? I recently installed 3" Rough Country Shocks on the truck and it does ride better but is there anything else I could buy?:crazy:
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Did you install shocks all around or just rear / front? Is that kit new springs and blocks or a spacer for springs and blocks?
anthony2558
New Jersey
Different tire chose, or just a tad less air in the tires.
Sent from my Pixel using Tapatalk
CoreyLRam96
CoreyLRam96
They are 3" shocks all around. And the lift method is drop spindles up front and blocks in the back
Gr8bawana
6.7 CTD
:confused:I for one don't want my truck to ride like a caddy!
DodgeTx
SEGUIN
Like everyone else said tires. if you used a spindle you shouldn't have had to change shocks up front. In theory if You used a spindle lift and a block in back it should ride the exact same as before.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Get a toolbox for the bed and fill it with stuff. It'll ride smooth once you get 700lbs of stuff in there.
goodtodoo
1996 indy pace truck
So I,m thinking of doing a lift on a 2wd short bed that's sitting here, What kind of kit did you use? How much lift ? From where. Thanks.
ChloeBrooks
