HOW TO REMOVE BACKREST VERTICAL BENCH 2015 Ram 1500 6 CYLINDER
Carib909
Ca
3.6L
I need to run a backup camera cable through the bed then outside to the bumper. I can’t get the backrest bench to fold down. I got the seat, but not the backrest.
Without modifications the backrest part of the back seat doesn't fold down.
Easiest way to get wires out of the cab from under the dash is through the plate where clutch pedal linkage would be. It's plastic plate and can be drilled through without removal.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Beneath the carpet, under rear seat, drivers side, you should find a rubber plug to pass wires thru. If not, you can always use a Uni-bit to make a hole and insulate it afterwards with Butyl tape, etc.
ameer73
