How To Remove Entire Engine & Transmission Harness Only?
Ramzman53
Flawda
Im removing my 03 1500 5.7 harness and everything leads up to thise one big part which runs across to the top of the firewall. Cant seem to find anything anywhere on how to remove that part separately and leave everything else or does it tie into other stuff? Also as you can see further back the carpet above the transmission is missing that clip which holds it up, does anyone know the part number? Thanks20241208_100720.jpg
