Harleymotorcycle
I have done a calibration actuator test on Alfaobd and everything passed but I have no heat on the driver's side but heat on the passenger side, few things I think of are the blend door, which blend door should I be looking at? Left Temp Actuator which should be behind the glove box, I have removed that actuator and seen it function, I have also moved the blend door and thought it felt good via the weight but how do I tell if the blend door is stripped or not or if it could be the heater core or something else?
