I have questions and need answers please!
DodgeRam3
I have a 2011 dodge ram 1500. It has 4x4 and has a 5.7 Hemi in it. I was looking at lifting and leveling it. I was looking at lifting it 2.5 inch or higher but i want to know what are good brands? I was looking at rough country but I have no idea? This is the first ram i have owned and i want to make it look nice! Any feed back would be much appreciated!
1500ram12
5.9L Cummins
Most will say adjustable bilsteins 5100 series shocks. They will cost more but give you a better ride. As far as a spacer I dainty think one is any better than the other.. Rcx hbs are about the same.
Sent from my D6708 using Tapatalk
JonF
Severna Park MD
Lots of options. Lots to read here. You could do Bilstein 5100 or Rancho QLL to level. They are a better option than spacers. And then add a 1.5" body lift. This would give you around 3 1/2' on the front depending on the level you use and where you set it and 1.5" on the back. You could add spacers on the rear springs, but then you would be unlevel again. This is probably the cheapest and simplist option unless you want more lift. Or you could do the level and some kits a level will work along with a true suspension lift kit.
No members online now.
Arturo Rojas
