I Need some help with Tires/Wheels
vcode70
Last week, I installed a Belltech 2/4 lowering kit on my '14 Ram 2x4 RCSB. The kit went on nice and easy and the truck looks awesome. To complete the look, I was thinking of bolting on some 22" SRT 10 wheels with 305/40/22 tires. What I would like to know is would I have any rubbing issues with this combo? Also, does anyone know of good place to order such a combo? Thanks!
HemiXpress
Discount Tire is one place to get that combo. If your going from stock tire size (275/60/20) 33" diameter to a 305/40/22 31.6" diameter, it will throw ur speedo off a few mph, unless you have a tuner to fix it. I don't believe you will rub, stock tire is 10.63 wide, 305's are 12.01. Hopefully, someone else with a little more knowledge on rims/tires will post. But I think u will be fine.
MikeG
Livonia La.
I'm using the same kit on a 12 crew cab with 22 BZO King lips with 305/40/22. I have very little rub at full lock. It's so little that I think it will stop rubbing after the tire get a little wear on them. Tire are new with 3k on them
