Ignition switch replacement
Reddeluxe71
Hey, I have a 2014 Ram 1500 Laramie Longhorn with the pushbutton start. I have just noticed that the button sticks. I wanted to see if this is a fairly simple replacement procedure, and if I get the part and replace will there be any flashing to be done or will the fobs still work with the new switch?
Thanks in advance for any help.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Have you considered disassembly and cleaning? I feel like I've seen something about the button itself being removable and there is the lower trim key whole underneath. Might be worth looking into...
Edit: Here you go, she's young but she has good instruction (just don't use WD40 but something like QD Electronics Cleaner).
R
Reddeluxe71
Saw that this morning. I think the little contact behind the button might be flattened and it is only a matter of time before I get stranded I'm afraid. Thank you
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I wanna say there "might" even be a keyhole under that button but that may be on other models.
ric221
Button is easy to replace. 4 screws and a plug. As far as I know no flashing is required, but I've wrong before.
