Immobilizer problem....
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
And also after reading what you were saying a little closer about you not seeing that no buss message all the time, there’s probably a good chance you don’t have a bad computer, just a bad connection more than likely.
Landolov
Garfield NJ
4.7 v8
Hello All I'm new on here and need help with my 2003 Dodge Ram 1500 5.7 v8
Won't start the check engine light doesn't come on with the turn of the key like it's sup pose to it did this before and it would come and go until now it doesnt start at all please someone anyone
Hi guys
I'm Michele, i'm a new member and i write from Italy, so i'm sorry for my bad english
I need help for my baby, a 2003 dodge ram 1500, that have a problem with the immobilizer, i think
Sometimes, when turn on the engine, after a few second it turn off and the red led between the gauges
I have a video on YouTube, can i link it here?
Thanks for your help
Landolov
Garfield NJ
4.7 v8
I have a similar problem just it won't start when the cycling on the cluster panel starts the check engine light doesnt come on until the end when it should be in the beginning of the Cycle indicating ecm is going through the proper sequence not sure what it could be need help myself
mimble
mimble
Perugia
So
I clean the battery terminal but the problem is the same
But when i disconectd the battery terminal i don’t switch on the light so i try another time...
I check another thing
When i turn in the inition the light goes in For a few second
I change all the lamp with a led bulb and i put on all a resistor for delete the error lamp on dash
Do you think if is possible the resistor is the probelm?
mimble
mimble
Perugia
Ok
But which is the bad connection?
Many thanks
mimble
mimble
Perugia
I don’t know if your PCM is bad, I’m just saying that from what I Googled, if you’re seeing a “no buss” message, that it supposedly means your dash, or in other words your instrument panel cluster has lost communication with your truck’s computer. That could be either in bad wiring somewhere, or a bad connection somewhere either from your pcm or from your cluster, or you could have a bad computer. Also I read that the connection harnesses at the computer itself were supposedly prone to corrosion inside the connectors.
I would start at the computer and check connections. Make sure you unhook both battery cables first, and cycle your ignition on and off, and turn your headlight switch on and off after you unhook the battery to make sure you depleted all residual power before you go messin with those computer connectors because if you didn’t have a bad pcm before, you might then. And once you let the magic smoke out, it’s toast.
Ok
I read many times to understand well what do you mean and now it’s ok
So the computer that you say is the pcm on the left side of the engine, the passenger side?
What i can use to clean the connection?
Thanks
mimble
mimble
Perugia
Another problem that i see yestarday, is that the obd2 plug don’t work.....when i put my obd adapter not work
I became crazy
