retired
I think Amsoil is worded kind of odd. It does not actually say it meets the ms-12633 specs it simply says use this oil for vehicles that take that oil. It just seems strange to me.
Amsoil SS 0-40 is MS-12633 certified. Look at the data bulletin on their website under “Applications” page 4.
https://amsoilcontent.com/ams/lit/databulletins/g2880.pdf
I have been using the EA15K50 since my truck was new in 2017. I have just recently changed to the EA017 filter. No problems with either filter. The longer one is a bit tougher to install as its a tighter fit (that’s what she said). I change my oil once a year, but I typically drive this truck <10K per year.
WIX actually makes the Amsoil filters per their specs. I used a filter for an F-250 for my old 5.7 hemi as it was considerably larger like the 017 filter.
unfortunate tho that they don't as if you have a new 6.4L you are taking a risk running it even tho it is probably great oil. while I am in warranty I won't risk it.The only oils Amsoil offers that are API certified are the OE and XL lines. The SS is not API certified.
As for any of them being MS certified, none of them are actually "certified". SS most likely exceeds the MS specs since it's not really a hard spec to meet. It just requires a lot of money and 2 years of tests before they can be MS certified and I'm sure Amsoil, Redline, Mogul, etc know their oils exceed the spec and don't feel it's worth the time/expense.
You misread. It's not MS-12633 certified. It's formulated to meet manufacturer specifications. AMSOIL has never been API or otherwise certified. Same with Red Line until they released their Professional Series of oils that are API certified.
