Improving Handling
broteinshake
New York
I'm not really interested in lowering the truck, but I just want to improve the truck's handling. its a sport quad cab. What coil and spring setup would you guys recommend? I already have the hellwig sway bar in the rear. Would the first step be to lower the rear 2" and install an adjustable panhard bar?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
What hole do you have the hellwig set up in. The handling can be affected based on the set up.
In addition, have you considered poly bushings vs rubber? That will make a difference.
Last have you updated shocks?
crazykid1994
There’s a bigger rear bar than the hellwig. Lowering the rear may help but upgrading the bushings to poly will help both the Front and rear sway bar. Are you 4wd or 2wd? You said coil so guessing 4wd. There is a bigger sway bar available for the 2wd front if you are 2wd. Upgrade the shocks to something better would help. The bilstein are stiffer.
16WhiteQC
Hudson valley, NY
I have Bilstein 6112's up front at 1.3" lift, out back I have fox 2.0, Tuftruvk1223V springs and the helwig in the center hole and I like the way my truck handles.
I was lowered on ground force 2/3 setup with the helwig and the truck really handeled great, but it road very firm so I swapped to the bilstein/fox set up and added the new coild down the road.
Robcar
Tualatin
Do you happen to know who sells the larger sway bars for a 2017 1500 2WD?
Randy Grant
KITTITAS, WA 98934
If you are having problem with front end dive in hard cornering, Hellweg makes a heavier front sway bar also. Between the two, and low profile tires and stiffer springs/shocks, It will firm things up quite a bit. Might ride like a buckboard, if its the sports car feel in a truck, that will help.
Zoe Saldana
california
6.4l
First, do some basics - you have a 2014 after all.
Rancho 9000XL shocks - adjust to what you like.
Do you have a steering stabilizer? If so, put in a new one.
Bushing - look at replacing
Do that and see how it feels.
Bigskyroadglide
Moderator
@Robcar The larger sway bar is sold by roadmaster and is available via etrailer.com. it is essentially the bar for the 2500 but fits the 1500. It's for the rear and the 2wd and 4wd bar are the same. For the front, there are very limited options
Bigskyroadglide
Moderator
I would suggest improving shocks, and go to poly bushings before spending $$ on a new front sway bar.
I didn't see change with the hellwig front bar and my 14RCSB corners like it's on rails.
Im running 5125 bilsteins, poly bushings and and a ihc lowering kit.
And no, it does not ride like a buckboard.
Randy Grant
KITTITAS, WA 98934
Didn't say YOURS did. Said if he did all I listed his MIGHT.
StickyLifter
TN
5.7L
I would go with IHC 3/5 drop kit with Bilstein shocks and the core 4x4 light weight rear control arms, Hellwig sway bars, and a Spohn Panhard bar. I only went with Belltech 2/4 drop because I tow a big trailer from time to time. It rides and drives just fine and you can fix the camber with offset upper control arm ball joints, but I might replace that stuff if I sell my race car.
