In need of black Trim protestant that will not run
icetraxx
My trim on my '17 is in pretty good shape so I've been using the 303 stuff as well as several others. Is there some non-water based product that will not run off down the side of the truck after a dew or light rain. From what I have been reading it is because they are water based. I wipe off any and all excess product as well.
My truck is black crystal metallic so it shows bad and I am tired of getting the truck looking nice be either leaving the black trim to look like crap or the areas under the drivers/passengers door and the sides of the bed looking like crap in 1-2 days. Any assistance would be greatly appreciated!
kkreit01
Olathe, KS
Unfortunately, 303 is one of the worst for this. It's great inside, not-so-much outside. For something OTC, I've had good luck with Megs Ultimate Black Plastic Restorer. I also like Surf city Garage Black max. I'm sure Adam's Black trim Restorer works well.
I
icetraxx
LOL spell check reliance either helps you or hurt you
quietpeen
2021 TRX
Hellcat
I would definitely try this. Their products are awesome
averageguy
Belleville Mi
hemi
When I read the title of this thread, I thought it was going a whole different direction.....
In todays politically correct world, any way you go with it, you could possibly offend a religion, a gender, or a race. Maybe even fit people because not running is a requirement. Well done sir.
Kinetic
Carpro DLUX and Solution Finish will both do what you want and they're both excellent.
Dave2018
2018,Previous 1998
3.6L,Previous 5.9L
Turtle wax black plastic restorer is a non-starter. I've tried it and it never lasts beyond a light rain. Going to check out some of the suggestions above. Thanks!
Looking at Adams, but $100? Anything in the $20 range that works?
BWL
Embrace the skeptisism
BC Canada
Lol. I find the really fat protestants don't run if that helps. On exterior vinyl I've had good luck with most brands of automotive leather conditioner. Seems to stay shiny even after a couple washes, but I haven't tried it on the plastic. Accidental the first time after doing the interior and leaning on the bottle while it was on top of my tonneau. By the time I wiped it up it was just as easy to do the whole thing.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I read somewhere (and on YouTube) that you can use ATF and/or a heat gun to restore the flat black plastic trim. It's the oils in the plastics that, over time, evaporate & dry out the plastic leaving it like a grayish or faded color. Using the ATF, you reintroduce those oils back into the plastic restoring it. And even a good brand bottle of ATF is pretty cheap.
gixxer
SK Canada
4.7L
Chris fix does something like this with a heat gun. It’s not a permanent fix. It will look good for a month or so and dry up worse.
joeygster
Ancaster, Ontario
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
As much as I love @AdamsPolishes im going to have to give this one to gtechniq C4 permanent trim restorer or should I say transgender black protestant
ChloeBrooks
