Inertia switch location???
Ddoles1986
Hemi 6.4L
Last night I got cut off and stomped on the brake. When I did the truck died and hasn't started back up. Been trying to find the inertia switch or an emergency fuel supply shut off switch. The truck just cranks and cranks, but never turns over. However if I spray starter fluid in to the throttle body it will start but die once it burns it off. It's a 2019 2500 with the 6.4. Any help would be greatly appreciated. Its Christmas day and not a very good one at this moment...lol thanks in advance
Mikey_2019
Denver
Was this ever solved for you? I had the same exact situation happen to me the other day. After cranking the engine on the side of the road I checked the battery voltage and was at 11.6V. Pulled the battery and put it on a charger got it up to 13V before trying to start it again. No luck.
Tulecreeper
The OP hasn't been on here since Dec 26, 2020. They made that one post and bailed.
turkeybird56
Central Texas
Search here for your setup to find switch: search for: (inertia safety switch 2019 ram 2500 6.4L)
Will tell you ref yer truck, U have several places can be.
