Inez Relocation Brackets or Control Arms
hdoggie24
Huntington Beach CA
Will the Inez no cut brackets work for a belltech 4" lowered spring that has been cut to 5 or 5.5" or no? Moe's website says the no cut brackets only work with drops up to 4". I do not want to get the cut version ones. If anybody can help that would be great. Thanks
ryan russell
Springdale Pa
They will work fine.. better then no brackets im sure
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
The no cut brackets are only good up to a 4" drop anything lower than that you would need the cut brackets to keep the axle from hitting the frame. As for shocks, leave the factory ones on there for now. If you like the ride keep them, I did and they work great. If you change them the ride will get stiffer.
hdoggie24
Huntington Beach CA
Weird and confusing looking at moesperformance website. If you look at the Inez no cut brackets individually, it says for lowering up to 4 inches. But when you look at the lowering kits, the drop down for the Inez no cut brackets say good for up to 5 inches. That's confusing, I think I'm going to contact Inez and ask them.
