Infamous Cruise Control Issue
Kotta390
Well I did a search for this and it seems to be a somewhat of a problem on these 4th gens. I am nearing 32k miles and I do ALL highway driving. My 2014 Ram's CC is a PITA to turn on EVERYDAY. It almost seems to be that the contactor for the switch itself is not working very well. To clarify, my On/Off button has to pressed hard to activate, but the other 3 buttons work flawlessly. Is there a TSB on this or does anyone know what is involved other than the dealer replacing the entire switch? I wonder if I should return my truck to stock for even this issue?
misuracaf10
I just started having the same issue... 20k miles 2014
SWsabre
AZ
Had exactly the same problem with my 2015, dealer replaced the switch under warranty and has been perfect since.
Kotta390
Kotta390
Well time to go to the stealership
Ram Man
FL
2013 Sport
Mine has a problem but I am thinking its related to my programmer...
Cruise shuts off if I hit accel too many times on the interstate. Doesnt shut off if I am going around town and press it though
BlownGP
Houston/Baton Rouge
Must be a 13+ thing.
09-12s have the stalk that I think Dodge has used for like 15 years. lol
I actually kinda like it.
7777xm
Covington, GA
My 2014 does not have that issue. I know there's a handful of people that do but I think most are fine
Sent from my SM-N920T using Tapatalk
Kotta390
Kotta390
Or it could be one of those "not IF but when" type of ordeals for the 13+
RamCares
n/a
n/a
I’d be happy to search for a TSB if you DM me your VIN. But since your vehicle is under warranty, I’d recommend bringing into the dealer for diag and repair – Kevin T, Social Connect Team
PDXRam
Portland, Oregon
MY 2016 1500 doesn't have more than 1500 miles on it and the "set" button is already wearing out. I have to push it way firmer than the other buttons for it to respond, I will take it in to the dealership if it gets worse.
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
LonghornSwede you better lemon law that truck before it's too late
miguelherrera4
Not necessarily. I have a '10 and mine doesn't turn on at all. I haven't tried disconnecting the battery for a while so it can reset tho. Some have suggested that method works.
Sent from my Nexus 6 using Tapatalk
BlownGP
Houston/Baton Rouge
Is there a fuse for the CC?
Kotta390
Kotta390
There probably is a fuse for it. I just wish mine would work without having to use 20lbs of force on the button...
miguelherrera4
I looked yesterday and couldn't find it ? I tried disconnecting the battery as well. Still no cc.
DRkNESS
South Jersey
Wow, I've had mine since 2010 and have NEVER used the cruise control lol. Time for a road trip to see if it even works. :)
Kotta390
Kotta390
Ill be honest with you. I have owned several Chrysler vehicles in the past, mainly trucks, and I have never had a CC problem.
jssmith76
Phoenix, AZ
The only problem I've had with my cruise control on my 09 (the stalk as I read earlier), is that as I'm coming out of a turn, and I "hover" my hand over the wheel, the damn thing will hit my hand from time to time, and I think I'm gonna break it. I would love to switch out my whole steering wheel for a 13+ steering wheel.
Sent from my SM-N910V using Tapatalk
