Infotainment upgrade
Ndkshns
Oklahoma
New here. I just bought a 2018 2500 tradesman crewcab. It's a commercial package that has the am/fm/Sirius center dash. I have a wrecked 2016 3500 with u connect, nav, and the larger touch screen. Can these units be swapped out? Also what about the heated seats?
I would really like having bluetooth and a few creature comforts.
1500ram12
5.9L Cummins
Yes everything can be swapped over. It may require a couple harnesses that @M2Mods @Mpgrimm2 sells. You'll also need alphaobd ($49 Google play store) obdlink mx ($60 Amazon) and the security bypass harness that @DeereGuy sells to program everything
2018 Ram 2500 6.4L Hemi Tradesman
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Spare post 16
While it's not recommended to install a 13-17 RAx radio in a 2018 or 19 classic it can be done with the correct parts but you 'CURRENTLY' can't get rid of Cellular System needs service error message at startup (unless using a 2018 UAx radio).
See...
Ram 2019 Classic RA2 to RA4 Upgrade.
I strongly suggest an 18 ram UAx radio in your 18 2500 truck. You will need...
- 2018 ram UAQ or UAS radio
- 13-18 8.4 bezel (Single or Dual Zone)
- 2018 2500/3500 HVAC module
- 13-18 7 speed fan resistor
- ATC Cabin Temp Sensor (below ignition switch)
- 4 speed conversion harness
with ATC cabin Temp wiring built in
- 4 to 7 speed fan resistor harness
& AlfaOBD/OBD Link MX BT adapter to change BCM config to Single Zone ATC
** AlfaOBD
- 2018 OBD Bypass harness (allow programming with AlfaOBD)
See ....
How To: Install a 2018 4C (UAQ/UAS) Radio in 2013 - 2017 RAM.
- DIY: 2013+ RA3/RA4 8.4" Radio Conversion Upgrade.
INFO - 2013-2017 8.4AN FW Notes (RA4/VP4 NA).
How to Add Automatic Temperature Control (ATC) to a Manual Temperature Control Truck.
M² Mods.
N
Ndkshns
Oklahoma
Thank you for the info. I was really hoping it would just be plug and play and go on my way.
joshhhh
