inner tie rod tricks?
99ram360
Maine
alright guys i need a little help here im changing the passenger outer tie rod, and the drivers inner bolt part just spins....i cant hold it tight enough to thread the nut on there...are there any tricks or anything you guys have come up with?
HKkid
Missouri
Have you tried a strap wrench?
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Use a impact gun and typical get it right off.
If you have to hit the bottom of the tie rod head upwards to drive the tapper back in the seat hopefully get it to bite again.
99ram360
99ram360
Maine
i don't have a strap wrench and i have tried hitting yet. i've already changed the tie rod im just putting everything back together. how much are the strap wrenches?
HKkid
Missouri
Not sure man....Harbor Freight probably has some decent prices.
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
If the balljoint shaft is spinning, take a pickle-fork and get it started, to apply a little longitudinal tension on the ball joint, then try to wring the TRE nut off with an impact. Speed and power is essential in getting that thing loose when it's in that condition.
Another option is to have someone apply a little steering tension to it w/o the truck running; all you're after is some resistance to the shaft to try and hold it. Again, use air!
Hope this helps, and good luck!
99ram360
99ram360
Maine
thanks ill go give that a try!
99ram360
99ram360
Maine
well we got her all on there...i ended up tying a rope around the inner tie rod where it meets the passenger side one and stuck a bar in it and just wound the crap out it and used the impact and it went on there...just need to get an alignment pretty bad now haha guess i didnt count the threads quite right...whatever :crazy:
99ram360
99ram360
Maine
ya its a lil embarrassing it took me 4 hours with a few breaks in between haha oh well though its done
Rogan68
meh, it happens! took me an hour last weekend to replace an oil pressure sensor on my Cummins.. I just couldn't get it, and it's a butter job to do.. Again, **** happens :)
Took me 7 hrs to replace 2 ball joints on my D60 front axle.. But it was a total PITA LOL
rambob
LA/MS
318 5.2l
I had to use a ratchet strap on my jeep
99ram360
99ram360
Maine
haha thats what i was gona use but i couldnt friggin find one...what you got for a jeep my old lady has a 04 tj with the 4.0 dogamatic though:slap:
99ram360
99ram360
Maine
i hate ball joints im hoping i dont have to do mine for a while
rambob
LA/MS
318 5.2l
I had a 99 tj. Traded it for the ram. It had the 4 cyl
99ram360
99ram360
Maine
sweet i like jeeps but hate working on it all the time
99ram360
99ram360
Maine
ya me too i feel a lot safer now haha. hopefully can get it aligned this week
