NETim
I replaced the PCV valve this AM since the truck has cleared 100K miles. No issues with the original, but I think it's recommended regardless.
Anyway, while disassembling the intake I was wrestling with the connector on the IAT. I gave the body of the sensor about a 90* twist and the entire assembly popped out. Upon re-assembly should a guy put a little oil or anything on the "O" ring to help seal it up again?
And to brag a little, I think I may have set a new world record with the engine cover replacement time. I did it in slightly less than 17 minutes!!!!!
