Turbovsix
Hi everybody -
I just installed tow mirrors on my 2010 1500 to help me see my boat trailer a little better. The units I purchased were from Amazon, and are made by DEPO - they are the flip up units identical to OEM, with the power adjust/puddle/turn signal/heated options. I believe they are also the same units sold by A1 Auto for reference.
Install was simple and the mirrors are solid - don't vibrate at all and are very well made. Direct plug and play. The convex portion of the mirror is very helpful and given the size of my trailer, I probably won't even need to flip them out when towing.
I need a sanity check on one thing as today was the first day driving with them:
1. Regarding the regular side mirror portion (NOT the convex) - seems like you could sort of go crosseyed looking into these. It's like instead of objects in mirror being closer than they appear, it's the opposite - objects in mirror are FURTHER AWAY than they appear in the mirror. I'm assuming this is because the large side mirror portion is adjusted so that the back of your trailer doesn't appear further away than it really is so you can see things easier. It just seems like there's a little distortion to the mirror - almost like you're looking through a magnifying glass to a degree. I see it in both mirrors. Again, my first day out with these and I'm sure I'll get more used to them.
Now, to adequately determine what's next to me, I basically have to use both the large side mirror and the convex to make that determination - using just the large portion, a car to my left seems like it's right on top of me when it isn't, and using the convex, it seems further away, so it's actually made it a little harder to judge changing lanes.
So, regarding the "distortion" or effect of the large side mirror - is it normal? Can't even really say that it's distortion - it's just "different" than a normal non-towing side mirror.
Any help or guidance would be appreciated. I was thinking of running an exchange on one of them through Amazon just to make sure what I'm seeing is normal but since I'm getting this view through both large mirrors on either side, I'm guessing it's just how they are meant to work.
Thanks in advance for any replies -
Rich
Rich
