Installed rear Rough Country N3 and new coil spacers. Question?
Ram7081
Hurricane 3.0
Update, I replaced N3 in the rear with V2. The N3 was to soft when I had gear in the bed.
First, I really wish I had gone this route from the get-go. I really am a fan of the ride. I have N3 all the way around now.
Ok, for the question. I added a 1" billet spacer and removed the 3/4" poly spacer. Shock was a pinch longer and wanted more lift to offset the longer N3. I noticed when I took the poly off it was lightly snug. If that makes sense. The billet ones had some play when sitting on the perch. I'd quess 1/8". Once shocks were all tighten up and it was ready to drive. The coil wouldn't budge. All good. Any thing to be concerned about?
Thanks guys.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Thanks guys.
I would recommend using top gun customz (TGC) rear coil spacers. They are consistent perfect fitting rear coil spacers. Did you clock the springs to the same position it came from the factory
Ram7081
Ram7081
Hurricane 3.0
I took a mental note where it was at. I didn't remove the whole coil. Lift it up, removed old and installed new.
Ill check out top gun.
Ram7081
Ram7081
Hurricane 3.0
I didnt see any at TGC. Might not sell them anymore.
ram1500rsm
Trabuco Canyon, CA
Thanks guys.
Get top spacers instead of the lower mounted ones. If you're buying lower mounting spacers then get something that can retain the coil springs down below, or make your own spring retainers with steel clamps. I had the 1" Daystars poly ones before. Super thick, zero noise and they have the groove for the coils to fit like a damn glove in the upper portion but they cost $100 lol.
Sure that might be hard for some to stomach spacers for $100 but they don't bulge, squeak or clunk, and you don't have to worry about the lower seat not fitting properly. Top spacers in our case work a lot better in the rear. i wouldn't do more than 1/4 rear spacers if using the lower seat but that's just me and what the offroad trails have taught me. Others may do things differently and that's ok too.
Let your common sense guide you and you should be more than ok.
Have fun.
VelocityC6Z
Maryland
Well ram1500rsm keeps beating me to the punch lol... I second that you should buy a set of 18" hose clamps, but measure it first, I don't know exactly how large they should be.
Just curious, which poly spacer are you saying you removed? The stock rubber upper spacer? If you took that off, I would probably put that one back on.
