Intake problems?
DRKSTR088
Magnum 4.7
Someone had told me that if I add a cold air intake to my truck I'm going to have issues, as in something break, because I have high mileage on it (190,000 to be more exact) he said I'd have to change some internals is this true? And if so what internals am I going to have to change?? Also if I wanted to change my headers would I still need to change out some internals?
usaf2006
North Carolina
I mean as long as you're not adding a supercharger you should be alright lol. I don't see how adding a cold air intake would do any damage to your motor... I would question their judgement
justin13703
MD
Lol whoever told you that you need to do internals for a cold air intake 100% doesn't have a clue what they're talking about. That's definitely one of the funniest things I've ever heard in the automotive world.
No, an intake won't break anything. No, that many miles doesn't matter. If you want an intake then put one on. Same with headers. Neither of these require any internal work whatsoever.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
That someone is a know nothing idiot.
You are not going to suddenly load up your engine with a CAI. Yes you have over achieved with your 4.7 but if its taken care of a little more air shouldn't cause any problems and there is nothing that will stop working. If anything, the engine will breath better and you may find a tick or two worth in faster throttle response (or not). On a 2002 4.7 you'll remove the OEM air hat which is a big air flow restriction because Dodge was trying to reduce under hood throttle noise with that design.
Two primary CAI types, open top CAI which are loud in a bad way (poser) giving a lot of throttle noise under the hood, and they really don't bring cold, denser air for combustion because they are heat saturated by virtue of sucking air from under the hood (K&N, AIRAID, etc).
The second type are closed CAI that suck from outside the vehicle usually using the OEM port in the right fender well or with additional ports. I don't know if S&B or Volant make a model for the '02. Also in this group is the Vararam which is semi-forced air for the Gen 4 Rams, but I don't know about availability or fitment for the '02.
For headers the thing to determine is if your replacement piping will displace any factory O2 sensors. If so the new piping needs to include ports to put the O2 sensors in. I don't remember where on the Magnum 4.7 that Dodge put the O2 sensors, but I do not recall them being in the factory header; I seem to recall they are down stream after the header joins with the piping to the catalytic converter. Short tube headers probably wont impact your O2's, whereas with long tube headers you may (may not will) have to address the location of you O2 sensors. A responsible vendor will already know and stock or order the right type of tubes for you. A word of caution, headers may generate additional horsepower (short tubes not too much worry, but think a bit before going with long tubes) that could change cylinder firing temps, exhaust valve seat wear, apply extra torque on your crank shaft and increased loading on your bearings. That's where that high mileage should be considered.
D
DRKSTR088
Magnum 4.7
Well he had told me because of the high mileage and the year there is a alot of wear on the parts so If i just now decide to start putting this much power into the engine I would or could experience issues with the motor. That's what I was concerned about and he's been working on cars since he was in high school had the same dodge as me but his was an 03 with a hemi and he has known me since birth
justin13703
MD
An intake and headers will not cause issues with motor internals plain and simple. Especially an intake, which often actually causes a loss in hp depending on which one you get. But best case scenario, with a good intake like s&b, you might see 5hp out of it. You will not grenade your motor with an additional 5hp. It doesn't matter how long he's been working on cars, if he tells you that you need internals done to put on an intake, no offense but he doesn't have a damn clue what he's talking about.
Now, if you put an intake and headers on it and run the dog **** out of it, then you can experience problems. But that is to be expected with any mileage.
Statcher1
Kentucky
Your not going to need internal motor work. Just for a CAI and a set of headers. Now you will need a tune to get the most power out of the truck after that. But if you drive it right and don't abuse your truck you will likely get another 50-100k miles out of it. But if you are hard in it and abuse it after the mods. You may not see another 10k miles.
THETANK
up jor *** mang
2015 R/T
oh my, I know just about zero when it comes to wrenching on vehicles and am just about as clueless when it comes to installing after market items. I am thinking your friend is into some serious mind bending drugs if he's giving you the advice that you posted about. Ask him if he has any extra and would not mind sharing.
D
DRKSTR088
Magnum 4.7
Lmao okay I get it maybe his old age has him stuck onto older cars or he's confused with some other stuff and didn't properly hear me at the Quince. But thank you all for the information and knowledge on this. My next question would be where and the hell could I order some headers and an intake and where can I get the headers installed? I can do it myself with my uncle but just in case he's too busy or something
Tray Burge
On the porch
Your friend is an idiot, stay away fro him.
HemiLonestar
Navy Badge Coast Guard
MD
Oh lord...this sounds like someone who would tell you to put an "electric supercharger" in your intake tract...
