The1ajrock
- Nov 30, 2017
- 8
- 1
- 2004
- 5.7 Hemi
Hi, this is my first post.
I just purchased my first Dodge, a used 2004 Ram 1500 with a 5.7L Hemi, with 200,000 miles. It was not running right, with misfire on Cylinder #7. We got a decent deal and my Dad is helping me to fix it. He has built a couple of engines before. He is a car guy. I am not so much - but I am learning.
There were no issues with oil or coolant leaks. We did not do a compression test (maybe we should have) but the engine was running.
We knew there was a mechanical issue, and took off the Driver side valve cover. There was quite a lot of sludge and carbonized oil debris caked over everything.
We found the #7 intake pushrod had fallen off the rocker arm. The pushrod seems straight and looks like the other pushrods. There the pushrod is not clogged.
The springs all look unbroken.
The pushrod ends seem to have a wear pattern on the end that is not hemispherical. it is like they have a groove. That same groove seems to be present in the rocker arm.
Valve stems seem evenly worn.
We pulled the head, and got the #7 Intake lifter out (that is the rearmost one, right?). It looks okay. The roller is fine. We pushed in the plunger/piston, and it stuck inside the lifter. we were able to get it to pop out with a pick. This seems like it might be why the pushrod could have fallen out.
Other lifters do not want to slide out easily. They move, but get "caught" on grime.
So my big question is how best to proceed (I am a kid, and cash limited) I see two options...:
a) Rebuild what I have
-recondition both heads $420-600
incl -cleaning - decking? - valve job - valveguides?, -stem seals
- new valve springs - I think yes
- what about pushrods, rockers, rocker "bars"? +$$$???
- what about replacing lifters? a set of 4? all 16? +$55 each set
- Head/Intake gasket set
- 2x headbolt set (torque to yield, so new oned required?) $60
b) suck it up, and invest in a rebuilt long block for $3349, with a $4yr warranty. Start fresh.
Any other things I should think about? I will take a few pictures to attach...
Thanks,
AJ (and Ken) Rock
Thanks,
AJ (and Ken) Rock
