interior water leaking
freespirit303
Hi Y'all.... I have an interior water leak..... at first i noticed the water would drain out of the bottom of the door once opened.... then i found the carpet under the back sit along the back of the truck very wet.... now i also found the compartment under the back seat is soaked....
any suggestions?
huntergreen
Marine Corps Navy Badge
Replace seal in third brake light. Most common leak.
Daw14
South Florida
Vents on the rear cab are common , use the search on this site as there is a long list of things to check.
andymax
Central Ohio
rear window fram crack is common, third brake light is common, shark fin antenna leak is common. spray with a hose until you find it. There are electronic modules mounted on the rear wall you need to worry about so find it and fix it fast. There a ton of threads about this issue...easy to find.
