Intermittent check engine light?
95360magnum
5.9 magnum
1995 5.9 auto 2x4 168k every once in awhile my CEL comes on if i have been on the highway for awhile, no change in performance, shut off and restart, then no light. Any ideas? Driving me bananas
sent from the interwebs powered by beer and gasoline
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Likely a misfire, your cat is going out, or your pre-cat O2 sensor is trying to retire.
Changed your plugs/cap/rotor/wires lately?
95360magnum
95360magnum
5.9 magnum
New cap rotor plugs wires coil and cat 7k ago replaced o2 4k ago, not feeling a miss....
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Tried resetting your PCM or checking for stored codes? Obviously there is an issue that it sees.
wingnut
Da Thumb
5.9 gas
Try a freebie scan from the auto chains. AZ uses crap, O'Riellys uses Innova. Slightly better. See what you can find first, then we'll go from there. I use an Innova 3160 that I got on Amazon for under $200. Best thing I've found short of a $3000 Snap-On, or a trip to the dealer. Paid for itself many times over. They love to say "O2 sensor", and then sell you one. Bad O2 reading is usually due to something else. But they do get slower with age, and not react as fast to changing conditions. This can also be seen on a good scanner.
95360magnum
95360magnum
5.9 magnum
Its obd1 they can't scan it, restting pcm helped, took it to a shop, they found nothing stored
Sent from my SGH-T999L using Tapatalk now Free
Reticle918
