Intermittent idle stall
Nibblez
5.9l
Hey yall. I have a 2000 ram 1500 5.9l. I have a issue that's stumping me. The truck runs amazingly.. but SOMETIMES at low ram at idol.. it kinda starts to bog down and stall out unless I stop it by giving it gas.. if I put it in neutral while it's doing it; it comes back to higher rpm for a short time and does it again.. I have replaced the plugs, wires, cap and rotor.. TPS and Idle air control valve, cleaned the throttle body (only what i can get to without taking it all the way off). THEN I found a vaccum leak.. it's some sort of port (nipple shaped) device that sucks air. It's located right under my Transmission dip stick but have no idea where it connects to.. I taped it up and the truck is still having the issue. Thanks for reading. If you have any questions I will answer them fully.
Nibblez
Nibblez
5.9l
These pictures are BEFORE I taped it up so you can see what it is.. thanks for reading.
dapepper9
Iowa/Nebraska Border
5.9L V8
Hey got your pm.
These pics show the vacuum line you're talking about. $10 says you don't have 4x4 right now because that line goes to the vacuum switch on top of the tcase.
As far the parts you replaced:
What plugs?
Dealer sensors? If not what brand?
Did you reset the pcm?
You can also try unplugging the front 02 and see if it runs better.
Btw, your username is my nickname at work :roflsquared:
Nibblez
Nibblez
5.9l
Spark plugs lol.. and as far as I know It still engages 4l and 4h.. negative I did not reset the pcm.. the tps was bought from napa.. I guess it's an oem part but definitely not mopar. And the iac was bought from advance auto.. that was oem as well but it diddnt say mopar on the box.. I'll let you know some more info when I get off work tomorrow. Thanks for responding. Nibbz came from my PS4 Gamertag.. which came from a drunk night fishing awhile ago lol
Sent from my SM-T350 using Tapatalk
Nibblez
Nibblez
5.9l
The plugs are. 40
Nibblez
Nibblez
5.9l
Pulling an engine code for torque converter P1740- No DTR... this is a JASPER Trans that was installed 20,000 miles ago.. they said it could be covered under warranty.. does this sound like it could be the problem?
bassslayer25
East, Kansas
5.9 360 V8
I dont think the torque converter has much to do with idling. I could be wrong but try replacing your o2 sensors. I replaced both of mine the day after mine died and stalled out because it was idling to low. After I replaced them it idles at 600 rpm every time.
Nibblez
Nibblez
5.9l
Hell yeah. That was my next step.. I think I'm still going to have jasper do the torque converter as well since my warranty runs out next month anyways lol
Nibblez
Nibblez
5.9l
I am pulling codes for upstream and downstream 02 sensors as well..
Nibblez
Nibblez
5.9l
How much money lol jk.. I appreciate the input. Those ******* are like 60 bucks a piece hahahaha those are located on the exhaust near the cat right?
bassslayer25
East, Kansas
5.9 360 V8
One is like 40 bucks or so and one is 60 bucks or so depending on the brand. And yes 1 before and 1 after the cat. And both terminals/connectors are up on top of the tranny. Kind of a ***** to get to but not to bad.
And soak the sensors in WD or PB before hand. Makes the process I whole lot less of a headache!
Nibblez
Nibblez
5.9l
Fantasticc. Thanks bud I appreciate it.
Nibblez
Nibblez
5.9l
I'll be sure to let yall know how it goes. Gotta check that vaccum leak as well. It goes into 4l.. but is kinda messed up sounding and hard shift.. I think I gotta look at the diffirentials after I fix these other issues
bassslayer25
East, Kansas
5.9 360 V8
Yeah for sure! Mine made a big difference.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
This truck should have an almost identical O2 setup to the 5.2L if memory serves. To replace the front O2 sensor you will need a breaker bar with a deep socket swivel that fits right over the sensor, same for the rear. If you put just an O2 sensor socket on there 80% chance the tranny is sitting in just the right place to wreck your wrench placement to where you wont be able to crack the sensor loose.
Since your replacing the old ones, just cut the pigtails, and use an O2 socket on the new ones. I broke both a snap-on and a buddies craftsman O2 socket trying to get my downstream sensor out. Put a swivel socket on there, had it out in less than a minute.
PBblaster is a must, without it you will want to light the truck on fire.
bassslayer25
East, Kansas
5.9 360 V8
You can rent o2 sensor pullers from autozone too.
dapepper9
5.9L V8
NTK is the brand you should buy. That's generally considered the best brand. Just don't buy bosch they have too wide a sensor range for readings and these trucks hate them
