I have a 1995 Ram Van 318/Auto, 75K original miles with a weird Intermittent "no crank" issue.
Van usually cranks & starts normally. But I will get an occasional "no crank" usually when temperature is below 50 degrees.
Symptoms are as follows:
Dash lights (check engine, etc.) come on when key is turned to "ON" but will not crank when key is turned to "START" position.
Outboard push button switch between batt + terminal & solenoid "S" terminal will crank the starter. This is my backup starting technique.
Battery shows 12.75V.
Starter relay tests OK per dodge manual test
New Neutral safety switch on tranny tests OK per dodge manual.
Battery terminals are clean & tight.
As temp falls below about 50 degrees problem gets progressively worse.
What am I dealing with?
Is the Starter relay a temp sensitive device & showing the first signs of failure?
Any help is much appreciated.
