Is it lifted or not?
dale clark
desert sw
CTD 5.9
New here....bare with me please
2006 Dodge 2500 4x4 CTD 5.9
I want to buy some new shocks for this truck. The ride is harsh. It's bone jarring when I hit a bump or pothole. Tires inflated to 50# all around. 285.75.17R AT "E" rated
I often tow a 6000# travel trailer
The sites for KBY, Rancho and Bilstein ask me what is the lift.
Each shock has it's own part number
I don't know for sure if it is or not. Not the original owner.
Looks pretty much like most other 4x4 2500 Dodge trucks.
Is there a way to determine if the front and rear, are at factory OEM heights?
Measure from the bottom of the front and rear bumpers to ground?
Some blocks under/over the rear springs?
Belphegor
I’ve got an 05 2500 5.7 SLB with a 2” front spacer. If you want I could give you measurements. Running 275 70r17, stock size. Should also mention it’s got the off-road package, not sure if that’s an increase in height. Often get asked if it’s lifted, even before the spacers.
