Thanks for the education.[emoji1]The two aren't even remotely comparable. One is straight gear and chain the other is clutched and electronically controlled. That's like comparing a 1ton diesel to a ram 1500 gas.
Yes.
pm sentYes.
Wild One Erased: "My truck will do donuts all day long with just the traction control off,on "dry" pavement,lol.You're just not making enough power,lol
My truck puts down 500 rwhp,and has no problem doing donuts ,in fact I've had it get a bit farther around at times then I've wanted if i'm not careful,lol.
Hmmm... You erased the first part above; maybe you tried it and realized I'm right about no donuts with yaw control, or maybe your truck isn't making enough horsepower... LoL...
Whole lotta talk Wild whatever, no video though... What's the matter Yaw Control got you by the forked tongue???
LoL...
Prove it.... No way with ESC on that can happen... Zero.
TC off will let them spin, but the truck ain't going sideways...
You so full of "it", you're buoyant.
Now, I gotta figure out an easy way to disable that yaw B.S.
As I was pulling the fuse last night I was thinking, wouldn't it be as simple as removing the fuse, slipping a wire connector end over the posts in that socket and running them inside the cab, remotely fusing that position while incorporating a switch in the line to deactivate it?
It's a 30A fuse though, so the wires would have to be fairly substantial... ?
It used to be so nice, like when I was stuck in a traffic jamb on a 2 lane road, to do a quick 180 degree NASCAR turnaround to go the opposite direction. But with a long bed crew cab truck, and the turning radius of an aircraft carrier that they have, that simple use of throttle and a modicum of driving skill is no longer available... Frickin' PC ********....
It's a 30A fuse though, so the wires would have to be fairly substantial... I wonder if there is a wire that is already run up into the cab which I could splice a switch into?
On my 2013, when I discovered they added yaw control to the vehicles, somebody told me "for a charge" the dealership could add a switch to the console to disable the yaw control, but unless there is a direct line to just the "yaw" part, I doubt they would add a switch which also disabled the ABS, etc...
Here's what I did.
Well John it's on we have to meet and do something spectacular. [emoji16] We may be put on a no fly list though lmao. Just a little blurt but once my cam is in my truck and it's running again I may and or may not be working on paddle shifters for the ram. [emoji6]" Or, I used an AGT WR-02 remote-controlled wireless switch to control the relay and "linked" it to a HomeLink (garage door) button. This saves the trouble of pulling wires into the cab and
installing a switch".
THE GARAGE DOOR BUTTON!
John! You are a flippin' SUPER GENIOUS!
Or, is it "Sheer Unadulterated Brilliance"?
Haas, are you talking about the switch in this thread from another brilliant person (Brandon) that makes it so your transfer case works like "real" 4WD? Or, I guess there is that Tazer-Ram module too, that says it disables ESC/TC too.
I think if we got Brandon and John together in the same room, they could probably fabricate a tactical nuke out of some moldy bread, a paperclip and a chewing gum wrapper...
LoL...
LoL...
