I've got issues...
rennaissanceman
Tampa, FL
Just yesterday I was stopped at a light when my engine just quits for no reason, I I popped it into park, pulled the key out, and then put the key back in and it started right up. Obviously there was some slight panicking on my part, but I was just glad it started up again. I have no idea why it did this. Also, though I'm not sure whether this is relevant or not but, occasionally when I'm starting it up I will have to hold the key longer than normally to get it to start. I could really use some insight to what might be causing this.
Sent from my Samsung Galaxy S3
MADDOG
Living in a Firepit
6.4L HEMI
Any check engine lights on Paul?
WhiteExpress
Midland, TX
Likely needs new glow plugs, or perhaps you are running incorrect blinker fluid.
Sounds like a short or a loose connector somewhere to me.
05singlecabHEMI
Lilburn,GA
i was gonna say the same thing. check the battery terminals. that happened to me a while back. when i went to a stop the truck would turn off. also check the voltage. how old is the battery?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Fuel cap could be faulty causing a vapor lock that would do the same thing to
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
Everything mentioned above with a nice tune up. Filters, plugs, wires, etc...
rennaissanceman
rennaissanceman
Tampa, FL
No check engine lights, but it has been a while since I refilled my blinker fluid, I think this time I'll go synthetic. But seriously, I will check all the wires, connections and the battery. Thanks a lot for the recommendations.
05singlecabHEMI
Lilburn,GA
i would suggest getting new battery terminal connectors if you still have the stock ones on there. When i had this issue they looked good. looked like they would get a good connection. then i finally changed them out and havnt had the issue since.
