Just looking for affirmation...(wheels/tries)
MR.Z06
Banned
So I want to keep the basic stock wheel and tire dimensions, maybe slightly more aggressive but with more tire and less wheel.
It came with the 20x9 and 275/60/20's
I'm going with a 17x9 5.71" back space and a +18 offset.
Tire will be a 295/70-17.
Thoughts?
Also the tire weighs 63 and the wheel is 28, so 91 pounds.
I've read several different weights for the OE combo anywhere from 75-86 pounds?
I was hoping to be closer on weight but oh well. How do you think ride will compare to stock?
Anyway I'm obviously new to the truck world. Thanks for your input.
BlownGP
Houston/Baton Rouge
That's almost the same as stock.
Should be fine.
and I think the stock 20s and tires weigh about 80 pounds.
That weight of that tire seems extremely high.
MR.Z06
MR.Z06
Banned
Yeah I thought so too but I'm just quoting the website.
HANKOOK DYNAPRO ATM RF10 LT
295/70-17
Weight: 62.86
Ronan
That might be accurate , I run 305/45/22 not a lot of rubber and they weigh 50.2. The website quoted them at 51.7. As for your tires, the height is only ~1/4 " difference (bigger) and almost an inch wider. I think you should be good with that. For the record my nitto terra grapplers 325/60/20 weighed in at 78lbs.
MR.Z06
MR.Z06
Banned
It's funny with the Evo or the Vette I'd be thrilled to loose a pound or even a 1/2 a pound off a wheel/tire.
Here I'm talking about adding 10-15 and it's not that big a deal...
DannyMK2
Long Island, NY
2015 Power Wagon
Thoughts?
depending on the tire and how aggressive the sidewall is you may get some minor rubbing. its going to ride a bit firmer because of the stiffer sidewalls. not a bad ride, most actually prefer it. stock tires ride like pillows. youll notice the difference in weight when you first put them on, after that it becomes normal. its not going to be a drastic difference.
MR.Z06
MR.Z06
Banned
Are the sidewalls really that stiff? The extra height doesn't cancel that out? Interesting. I had thought that it might ride the same or even a bit softer because of the extra sidewall height.
I should just keep the stock set up but I just can't wrap my mind around a 4x4 truck with 20" chrome wheels. (I guess that makes me an old)
DannyMK2
Long Island, NY
2015 Power Wagon
the extra side wall from 17" wheels does add cushion compared to say a similar height set up with 20" wheels and e rated tires, but not compared to the stock set up. the stock tires are super soft. its not a bad ride or super stiff, i preferred it. feels more like a truck and less like a car. but yea, its going to be a bit stiffer then stock.
AustinB
Banned
San Diego, Left Coast
Personally, I would go with a 0mm offset.
Just helps if you ever decide to go wider down the road...and not have to buy spacers.
IMO
MR.Z06
MR.Z06
Banned
I was going to but I wanted to stay close to stock so they would have less to complain about if I ever need warranty work on my suspension.
I have the lifetime warranty and I don't want any hassles.
As I have the air suspension I'm pretty sure it's going to be needing work sooner rather than later.
joshhhh
